Guys,
There is always going to be positive and negative on a product offered.
It is not personal. Feedback is knowledge.
Positives and Negatives;
+ The bolts are longer and have more thread that engages.
-Nobody has ever had the supplied bolts break or strip out. 22ft lbs only.
-$75 is costly to replace something that works fine.
+ Aftermarket NX billet SC lid may be thicker and need the additional length.... ?
- or it could be thinner and these bottom out and the supplied ones remain and you wasted $75
+ Replace rusted bolts
- If you painted the bolt heads before install they are not rusty and these are not needed.
I searched google for longer bolts in the past and could not find them in stainless, not even in zinc. Likely could order them in bulk, but not just 10 of them. So, I gave up on it.
Keep in mind, x1 bolt thickness going into steel and x2 bolt thickness going into aluminum is adequate for thread engagement.
I bought a set just in case the NX billet lid is a little taller, that is my reason. Worth it to me so I don't get stuck looking for something when I need it.
Now everything can go back to normal.
Please!!!!, everyone stop being so sensitive and having hurt feelings all the time. 👍🏻👍👍🏽👍🏿
