1 - 17 of 17 Posts
So I’ve developed this squeak/whine over the past 2k miles and I can’t ignore it any longer. This is the car at idle. The noise is audible from inside of the car as well. 16k miles on this A8 2018 hellcat.
Goes in on November 1st for a check on this and a drone/humming noise that starts at about 70 mph and gets progressively faster the faster the car accelerates. I will get a video of that from in the cabin and post here as well. Hellcat squeak/whining noise…BAD??
Discussion Starter · #2 ·
Also yes I saw the star screw on the SC was backed out quite a bit. Not sure how the hell that happens since it has never been off of the block 🧐 I did tighten it back down.
· FCA Official
Hi Destroyer_707_,
If we can be of any additional assistance as you are working with your dealer, feel free to send us a private message. We'd be more than happy to help.
Rob
Dodge Cares
Discussion Starter · #7 ·
Took it to the dealer and he put a stethoscope around the entire thing. Couldn't pin point any specific area. We will dig into it deeper on Nov 1st. The squeaking does get a bit faster and more pronounce while decelerating
Hi Destroyer_707_,
Rob
Dodge Cares
Hey Rob,
Thank you very much. Any thoughts on the noise that is in the video attached??
Discussion Starter · #9 ·
@DodgeCares
This is the second noise that is coming from inside the cabin. I best describe it as a vibration noise that sounds like something rotating every 1-2 seconds. It’s a deep noise. Vibrational noise. Can be heard inside the cabin. 2018 A8 Hellcat Widebody. What is it????
Drive shaft seems to be completely fine and has no play. Just changed my diff fluid and there was very little if any metal shavings. Fluid was on the cleaner side actually. Slight whine coming from it but all of my 392’s and hellcat have had some diff whine with proper break in procedures.
· FCA Official
Hey Rob,
Hi Destroyer_707_,
We are unable to speculate regarding vehicle concerns. We rely on the diagnosis of the dealer. What we can do is escalate a case on your behalf so that one of our Case Specialists could work alongside your dealer to find a potential solution to the concerns you’re currently experiencing.
Rob
Dodge Cares
See if it changes when you put a socket on the supercharger tensioner.
21 Challenger Redeye, 21 Trackhawk
Mr. King,
I have to ask, do you read any other part of the thread except for the very first post?
Or even the dates of the posts?
I'm really not trying to be a smart-ass here but if you did read you would know this issue was sorted out 3 months ago.
1 - 17 of 17 Posts
