1 - 4 of 4 Posts
Is there an alternate way to measure these temps? Just remembered, it does display in the DIC SMH.
I upgraded to a new UConnect but the IC Coolant temp doesn't work ( I understand there is a TSB only on this atm).
Just on the center between speedo and tach. I doubt there'll ever be a fix from Dodge. It affects any vehicle that's had the Uconnect replaced whether upgraded like we have or original that went out and was replaced.
Grand Cherokee Trackhawk
Same issue I had, I have an 18’ TrackHawk and I replaced my infotainment system cause my GPS was saying I was in Cuba and after replacement my I/C widget stopped working. A fellow member on another TrackHawk forum fixed the problem by replacing the 2018 BCM in his TrackHawk with a 2019 or newer BCM and once reprogrammed the I/C widget worked again.
1 - 4 of 4 Posts
