1 - 11 of 11 Posts
hey all....2016 challenger hellcat. i just replaced my battery & noticed my clock was 3 hrs off. I went into clock settings & noticed the box was checked (sync clock with nav) when i uncheck the box the time is correct...if i check the box it changes back to 3 hrs off & it wont let me change the time if the box is checked....any ideas?...thanks all...
Let it have overnight...
What he ^^^ said. Takes time.
Discussion Starter · #4 ·
i just checked & still no change...i just went online to uconnect & found theres an update for the 2016's....downloaded it & going to install .....hopefully this will fix my problem.....will update later....
Have you checked your Settings to make sure your Clock sets Automatically and your GPS Settings are good??
Discussion Starter · #8 ·
when i check the box to syns clock goes 3 hrs behind....uncheck box & I'm able to set manually....all happened after disconnecting for battery swap....uconnect customer service says update needed....radio reset when i disconnected it... we will see...
2021 SRT Super Stock
again, probably has something to do with time zones. have you checked your nav to see what city it's set for?
Discussion Starter · #10 ·
didnt think of that, will have to check....would it still show my proper location on the map? if that was wrong?
Discussion Starter · #11 ·
update... I upated the software & problem solved....thanks for all the input.....
1 - 11 of 11 Posts
