1 - 3 of 3 Posts
I have a supercharged built Daytona 392 with the trans tuned. I wanna get the tazer to unlock the track modes so it stays in lower gear than sport. And also to change the cluster to srt style. Is it going to affect my trans tune as is it worth it.
2015 Charger SRT Hellcat
should not negatively affect TCM tuning in any way by using a Tazer, but if you are trying to force a gear, what is your opposition to using manual mode or paddles? Keeping in mind if you are running an A8 in any dynamic mode, it will shift more quickly and decidedly than a manual driver (which is reliant on intuition) and you can use either of the two options I mention initially to "force a gear" to be used safely.
‘16 A8 Shaker
Oh wow sorry I didn’t see this sooner. Did you install a tazer yet or not? It will unlock track mode in the bcm (change how the apps work) but I need to give you a heads up if you have not already started using one. They need to make a sticky here really, if Ian isn’t gonna change the instructions, a “before you start changing anything” sort of thing
1 - 3 of 3 Posts
