Strengthen diff case, help with wheel hop and increase rear end bite. Most people recommended DIRS diff brace but I’m holding off to see if having one actually helps. This one was about $200 less than DIRS..What does this fix/improve? I never heard of this one.
So waste of money?Diff brace helps hold the case together, yes
With rubber mount, slotted holes, and bolts that you can barely tighten, it does not do much to hold the housing in place tho
If I were only going to change one thing back there it would be to lock out the housing
Definitely will! Which brace are you running?@SPDBoat A Diff Brace is a Mod that I call "The Best Peace of Mind" part you can install.
Without it and the Diff box breaks. It can take out the Driveshaft, and or a half shaft!
I know because I did!
Take some pictures while you are installing the brace, we'll be looking for ward to your thoughts!
Linda![]()
Never mind I just saw your build sheet! If this doesn’t hold up that’s the one I was considering nextDefinitely will! Which brace are you running?
I have seen lot's of satisfied customers that installed TBAsNever mind I just saw your build sheet! If this doesn’t hold up that’s the one I was considering next
No, it serves a purposeSo waste of money?
