1 - 18 of 18 Posts
been hearing these noises in the front of my hellcat widebody charger. Car only has 5500 miles. I dont know how to describe the noise that it is making but I feel it in my throttle when I hit about 40mph. it kinda sounds like a clunk/creaking. it also makes the noise when im down shifting. if anyone has idea lmk thxs
Super Moderator
It's possible that you hear the 2 pc Brembos clicking.
Linda :)
I dont think it's the Brembos. I’m thinking that at 40 theyve pretty much settled in already.
Reactions: OldMoparGuy
When you say you feel it in the throttle do you been you feel it in the gas peddle ??
Have you checked front sway bar and struts? Sounds more like a suspension issue.
Super Moderator
Do you have any modifications to your Hellcat?
Linda :)
2016 Bright White Challenger
the only mod I have is dynomax racing bullets foe the exhaust
Possible whoever welded the bullets in, has the exhaust sorta under load from not cutting it to a proper size? Under heavy load the engine will obviously move a little bit, could be your exhaust hitting your underside which would occur under high rpm (when your downshift as stated) and the feeling in your throttle is more pronounced because its a deeper exhaust note. does it replicate in all modes and shifting settings or just track or something rather violent? Tried using paddles and downshifting manually?
Maybe drive shaft center bearing? Hard to guess but may be worth it to take to the dealership as it should be under warranty assuming it's not the exhaust.
Discussion Starter · #16 ·
Iv had the exhaust done at 1500 miles and never at a issue. and iv used the paddle shifters it does it as well and it happens in every mode. I thought it might be the transmission
Any play in drive shaft where the carrier bearing is?
Any odd play in the steering wheel? Turn on and turn wheels to full lock and see if you hear anything clicking could be worn end links or something stupid
1 - 18 of 18 Posts
