REVIEW & DIY: JLT Intake for 2016 Challenger Hellcat | SRT Hellcat Forum What do these 43 people think????????
I know, I bought your lower from your last car haha. I've noticed the AIT is great until you start to do some runs then it heat soaks. I had looked at the one that comes with the Daytona and it's different than the JLT. It doesn't seal to the hood as well as the JLT does plus it still has that silly accordion tube connecting it.I added the Hellcat intake box on my 3x 392's and then had the Mopar open intake (from the factory) on my last Daytona 392.
Didn't really notice a sound difference and the intake temps were way higher/hotter on the Daytona.
I'd skip it
Keep in mind, this was from 2018 before they did the redesign of it. They made a bunch of changes.REVIEW & DIY: JLT Intake for 2016 Challenger Hellcat | SRT Hellcat Forum What do these 43 people think????????
You have a HC so it's a bit different but from what I know it's better air flow, you can hear the SC whine a lot better, and it growls louder. I'd have one if I had a HC just to hear that whine and to smooth out the airflow.I have a 21, and I don’t see where there is an advantage over the factory one i have? Am I wrong?
I just sent out my TB to Fastman to have him port that and I was thinking about replacing the intake with the JLT. I already have the HC lower plus the bumper portion installed but I was thinking of getting the JLT to smooth out the airflow since the stock pipe has the accordion portion. Eventually I was hoping to pick up the Redeye Charger hood with the ram air so the stock box would eventually need to be upgraded anyway.
I have no interest in doing the LMI since I do drive this car for three seasons.
I believe he means JLT did a redesign of the intake system as a whole across all years.![]()
Hellcat/Redeye/Demon Air Intake Designs
Goals: greater than OEM filter surface area (increased area to flow clean air; increased dust capacity) close to ambient air; air sourced from outside the engine bay less restrictive intake tube; least restrictive design will yield the largest performance gains on supercharged/modified/heavily...www.hellcat.org
Didn't see much change on the JLT site between 2015-2020 intakes vs 2021-2023 intakes.
JLT Cold Air Intake for 2015-2020 Charger Hellcat & 2015-2018 Challenger Hellcat
Check out the JLT Cold Air Intake for 2015-2020 Charger Hellcat & 2015-2018 Challenger Hellcat at S&B Filterswww.sbfilters.com
JLT Cold Air Intake for 2021-2023 Charger & Challenger Hellcat
Check out the JLT Cold Air Intake for 2021-2023 Charger & Challenger Hellcat at S&B Filterswww.sbfilters.com
Correct, I have no idea what they changed though. I'm guessing they made the fit better so people didn't have to trim them like the one guy did.I believe he means JLT did a redesign of the intake system as a whole across all years.
I could be wrong tho
One thing I don't like about their "adapter" for the tube though, is that it's just a thin piece of foam with adhesive on the back. It can't be very supportive.keeping the tube and the grill piece and getting the JLT.
Yeah I saw that. I was thinking about a 3d printed piece with some built in clips to hold it to the outside of the JLT.One thing I don't like about their "adapter" for the tube though, is that it's just a thin piece of foam with adhesive on the back. It can't be very supportive.
Tube holds in just fine. That adhesive backed foam is super sticky and not going anywhere. Zero concerns with that portion of the box. The one negative to the JLT IMHO is the rain shield solution for the earlier cars that have the heat extraction vents. I didn't like that it basically completely blocks that vent. I modified an AFE rain shield for my JLT which allowed that vent to stay open and still divert rain water from the filter. Others use a sock.One thing I don't like about their "adapter" for the tube though, is that it's just a thin piece of foam with adhesive on the back. It can't be very supportive.
The tube is actually different on the Charger. It's much longer and a HUGE PITA to install/remove versus the Challenger tube.- edit - Just realized this was in the charger section. My feedback is based off the challenger platform. I'd assume the tube design is the same and the "benefit" of increased sound should be the same. But the rain concerns is probably different.
That's why I was thinking if you had a 3D printed part it could work really well. I'll have to dabble when I get mine.The tube is actually different on the Charger. It's much longer and a HUGE PITA to install/remove versus the Challenger tube.
The stock air box provides stability/holds up the back of the tube (along with a push pin further up the tube)....so I'm not sure if the foam is supportive enough, if that makes sense. I'm sure it works though....but it seems like a huge afterthought IMO, on their part
