They fit in F14's so, I am going to say, yes. With the F14's everything is very much like an OEM wheel.Anyone know if the oem tpms sensor/stem will fit in a D5 18x5?
ThanksThey fit in F14's so, I am going to say, yes. With the F14's everything is very much like an OEM wheel.
. View attachment 576508
Nope didnt work. I get about 3-4 runs in a night with cool down in btwn. plus you start and stop in the staging lanes. Ive even left the setup on the car for a week after race night and never resets. I went ahead and ordered a new set thanks to @dragrcr and to Forgestar who says the inner construction is the same for the F14 & D5.It says several cycles, so maybe a few start/stops?
Hmmm lol. Ill be putting nitrogen in the fronts seeing as I dont change the psi in those like the rears.With TPMS, you can run helium in those bubbers, too, It leaks out faster than normal air, but some weight s(h)aving.
Yes they do. I just installed my D5 front runners last month with TPMS and the MT Sportsman SR.Anyone know if the oem tpms sensor/stem will fit in a D5 18x5?
Helps the front end lift as well...With TPMS, you can run helium in those bubbers, too, It leaks out faster than normal air, but some weight s(h)aving.
All about that wheelie lolHelps the front end lift as well...
