1 - 12 of 12 Posts
Challenger SRT Super Stock
I purchased the below sensors for running Demon front runners on my 22' SS. The tire shop says that they can't get the sensors to pair with the car. When I contacted the seller from Ebay, he tells me that the sensors only measure to 44 lbs. Has anyone use factory sensors over 50 lbs? Any recommendations on aftermarket TPMS that would work?
Rectangle Font Circle Screenshot Brand
2022 SRT Super Stock Smoke Show
I purchased the below sensors for running Demon front runners on my 22' SS. The tire shop says that they can't get the sensors to pair with the car. When I contacted the seller from Ebay, he tells me that the sensors only measure to 44 lbs. Has anyone use factory sensors over 50 lbs? Any recommendations on aftermarket TPMS that would work? View attachment 596697
I have a 22 SS and just went through this drama. Just so you know 22's changed everything. Pre-22 sensors will not work. They are a whole different sensor and not backwards compatible. I would wager these will not work with your car.
I went with OEM Dodge sensors from Dodge installed by Dodge and they work fine with my Demon fronts at 70+ PSI.
Even the old sensors would show tire pressures of 50 psi or more when the dealer would forget to reset the pressure to 32.
Thanks! Any chance that you have a part number? Side note, what tires are you running?
No sorry, after dealing with a local tire shop who left me in the same boat you are in, aka sensors that don't work, I took it to Dodge and they handled it all. Had to pay the "Dodge Tax" and it wasn't cheap but they all work flawless now. I bet if you call your local Dodge dealer they will order them for you. My tech at Dodge I was talking to said apparently the new ones don't need programming most of the times the computer just picks them up after driving a bit? Sometimes he said they have to go in and enter the serial numbers but 99% of the time with the 22 OEM sensors they just auto load.
Also my stock wheels switch over automatically after about one-two power cycles of the car when swapping with the drag pak.
.2020 HCNBM6. ...2022 RENB...
Discussion Starter · #10 ·
Did they work? I didn't see the posted results. And you mentioned that the part numbers were different?
I don't know if those work, I provided the link so you can see where we are. I bought some OEM's and waiting for the dealer to mount, the tech is on vacation this week so hopefully next week I'll know how the OEM's work and if they need programming.
1 - 12 of 12 Posts
