1 - 17 of 17 Posts
hey all,
Going to the track in couple of weeks first time, mine is a narrow body charger stock with 305 Nittos 555R2 and 275 michelin S3.
I know the car is not great for tracking, Id appreciate some tips regarding front and rear tire pressure settings, how much gas in the tank for weight , driving tips.
Much appreciated
cheers
'23 Redeye Jailbreak
Never ever road track a car on drag radials. First off, most tracks will fail your tech inspection if you show up with drag radials on the car. The risk involved is sudden total loss of control of the vehicle under heavy load. Drag radials have soft pliable sidewalls, which are great for straight-line traction, but very poor for lateral grip. At high loads on a race track, you run the risk of a loss of control event during hard cornering. This is how you see what it feels like to hit a tire barrier and how much money it costs to fix (and most tracks also bill you for damage to the track too).
In short, don't track the car on drag radials. You'll need a set of proper handling tires set likely between 35-40 psi. It depends on the tire compound, temp and road surface as to what setting offers the best traction. You'll have to experiment.
For the Hellcat, gas isn't much of a factor. I'd keep it above 1/2 tank due to the propensity of the Hellcat to float the fuel pumps under high G loadings (which occurs mostly under 1/4 tank). The Hellcats weigh over 4,800lb loaded, so weight distribution caused by an extra 1/4 tank of gas is going to be inconsequential. Your biggest issue is the drag radials and the must-have removal of those.
Driving tips for any new driver...
Prior to the track day, ensure your brake pads and rotors are GOOD, your brake fluid and coolant is nominal, and all suspension components are good. Shouldn't be an issue on a new-ish car. After the track day, do it again. Track days are hell on a car and its tires/braking system. Some folks will pay for a post track day maintenance depending on how hard they drove and for how long.
On track day, spend the first few laps very conservative. If available, do a ride-a-long with an experienced driver on that track to learn the course a bit. If that's not available, you have to do that part yourself. Learn the track, note where the apexes are, identify any "gotcha" zones... places like a long straight terminating into a sharp turn, where there's rises or humps in the road surface during the braking zone that can cause the car to hop up on the suspension (and lose brake force).
Remember that this is more than likely your street car, and not a race car. Have fun and drive well, but trying to keep up with other track focused cars on the course is a fool's errand and pushing your car past its limit rarely ends well for the street car on the track. If you start to get into uncomfortable situations, regardless what Dodge says, lift and recover. Listen to and learn what the car is telling you. In my experience, a Hellcat is one of the absolute worst track cars. They're fun, especially since driving them aggressively generally means you're drifting most of the course (or snow plowing through turns with the heavy oversteer these things have). While the sensation, sound, and feel are very much fun, the actual track performance of the car is relatively poor. There is no graceful corner carving in a Hellcat. There's pretty much lots of smoke and noise... and if you have a car club like mine, every time I tracked the 'Cat, they'd shout "FREEEE WILLY" every time I passed the finish line. It is in fact a land whale and feels like it on a road course. Especially noticeable when I'd bring the Lotus and swap cars mid-day.
Discussion Starter · #4 ·
Oh man!, glad I asked!!, really appreciate your comprehensive response, yes my nittos served me so well on straight line races , didnt think would be this dangerous on track thu, but you make sense. Id love to get my hands on Toyos for track stuff, I do have a brand new continental extremes though! maybe put these on? and roger that for gas. As far as PSI are you talking on all 4 corners?
It bears repeating that you should check with the track prior to going to find what the tech requirements are. Most require just an approved helmet and no other safety gear. Some do require in-cabin fire extinguishers for certain classes of car, and they often mandate acceptable tires. Most tracks I have driven on won't allow you on the track with drag radials or wheels with excessive spacers.
Discussion Starter · #8 ·
Will do thanks!
any time is a good time to do a well run hpde....meaning first timers should have a mix of classroom basics and on track instructors in the right seat. I would recommend regular street tires, as dot drag tires are suboptimal for road course..
If the experience of driving your street Dodge on the track is the desired end, then, no need to just spend a few grand on some thrasher track beater with outsized grippy tires and slammed suspension to chase after that ever-elusive dream of the fast lap times.
Dodge grand touring. What other car can allow you to take four friends out for a fast-paced driving session?
If you have the stock brembos word has it you should be OK. If you went to Z23's like many other people you won't like them when you heat them up. Go back to your Brembo pads or high performance pads for any hard driving.
1 - 17 of 17 Posts
