1 - 11 of 11 Posts
Does anyone know the spec? The wiki says 89in/lbs but the bolt I tried that on snapped right off; never even got close. Yes, I’m using new bolts (well I’m using all new except that one now).
Discussion Starter · #7 ·
I know this is an old thread, but always good to replace any torque to yield bolts with steel bolts if you can. Torque to yield are single use only. This way you don’t have to worry about breaking them, and you can reuse steel bolts so you don’t have to get new ones if you have to get back in there.
1 - 11 of 11 Posts
