1 - 9 of 9 Posts
Some tree sap got onto the vinyl stripes on the hood of my 2017 Charger HC.
Anyone have any ideas how to remove the sap without damaging the vinyl?
Discussion Starter · #4 ·
Thanks for replies.
I found a website that gives a lot of good information on vinyl wraps.
For tree sap - Should be cleaned quickly.
Denatured alcohol or isopropyl alcohol 2 parts and water one part. That's pretty simple and cheap.
Sadly, the sap dried months ago and is hard.
2020 Challenger Hellcat
Depends on the vinyl... if factory vinyl... honestly.... water. Soak it with water. Remove gently with the softest, thickest cloth you can find. If that doesn't work, as others have mentioned, try the diluted iso-alcohol. If that doesn't work, try diluted Goo Gone.
If it's a custom deal, it will depend on the vinyl quality and what coating is on top of the vinyl. In addition, it will also depend on how old the vinyl is. Newer vinyl is more pliable and can heal to a degree from things like this with GENTLE heat treatment. Vinyl that's 3+ years old, no such luck usually.
I've had trouble getting tree sap off my daily. Haven't tried wd-40, so will give that a shot
It works great to get all kinds of stuff and rubber off the car. Will not hurt paint. Keep away from black plastic it will darken it.
Robert
1 - 9 of 9 Posts
