1 - 20 of 24 Posts
There's a bunch of posts on ChallengerTalk that say they are the same and will interchange.
And 2017 was the last year you could get a Challenger without a factory spoiler.
‘16 A8 Shaker
A8 low gear 4.71 reduction
Stock rear 2.62 reduction
To spin axle 1 revolution crank turns 12.3 times oem
With A8 his 3.70 gears crank turns 17.43 times
That’s over 40% more gear!
Font Rectangle Screenshot Parallel Number
Yes you are going to see some serious shit!
If it hooks might land on its own roof : )
Discussion Starter · #16 ·
Pretty sure full weight, if something doesn’t catastrophically explode, the front wheels are coming off the ground
‘16 A8 Shaker
I believe the car now has something like 14x torque multiplication in 1st gear
No, your current combo has 17.43 ^^^
Did the math for you ^^^
That would be with a clutch tho… flashing the converter multiplies torque even more : )
You say you have over 900 rwhp… how much torque did it make at 3000 rpm?
1 - 20 of 24 Posts
