21 - 29 of 29 Posts
I didn't take any pictures of the Dart and I'm not sure if it won any awards or went to the Crusie of Champions. Regardless it is a very nice ride.
Reactions: Fastmanefi
That's a great build! Total BAD A$$. I wish that I could see the grin on the driver when he smokes the unsuspecting opponent and the what the hell just happened look on their face! Happy Throttles!!!
Is the 2nd throttle body you're referring to - the "bypass valve"? I assume that means there is some black/red key stuff going on too, right? That would be awesome.
Banned
Jack, the second throttle body is the blower bypass valve. it is actually a throttle body from a new Dodge Dart I think..
Discussion Starter · #26 ·
Yes, the second throttle body is essentially an ECU controlled blow-off valve. Tricky to control with any aftermarket ECU but the Holley Dominator can do it. I did not build the car - I only did the electronics and did the tuning. Here's a link to a video from the guys at Dominator Street Rods that built the car.
I had the opportunity to tune a Hellcat motor going into a 1968 Dart. The ECU is the Holley Dominator because that ECU can handle all the Hellcat sensors such as drive-by-wire, the two throttle bodies, and even the two knock sensors. The results were great. I think the Hellcat could make a nice crate motor for hot rods and the Mopar crowd
fastmanefi
Just curious if holley is still the way to go for a hellcat redeye? Is there Anything out there to control the 8 speed transmission?
I find myself in the same situation, I have a Holley Dominater, but I'm setup for a drive by cable throttlebody. This winter's project, I'll be adding a 4.9L Bigun Kenne Bell Hellcat/Demon kit. Fastmanefi any write ups on how to wire and configure the Dominator ECU to control the bypass valve?
21 - 29 of 29 Posts
