I, somewhat, recently purchased a more than gently used 2016 HC Challenger and have had issues with the turn signals since day one. Apparently the previous owner was fascinated by cheesy stickers and cheap, poorly installed halo kits.
The drivers side front signal light would come on occasionally but, typically, only for long enough to flash once or twice then die. I solved this by replacing one of the circuit boards inside the housing which I found a blown microchip on. Luckily, you can find these parts off of wrecked cars on EvilBay very cheap.
The passenger side has me stumped now. It operates perfectly although the DIC shows that it has issues and it audibly (in the interior) flashs much fast than the repaired drivers side. I have monitored it and see no issues on the front, back or anywhere else imaginable.
Has anyone else dealt with such issues? If so, any idea as to where I should investigate?
I loathe the idea of opening the other light but will if I must as it is quite annoying to daily drive a car that believes it’s turn signal isn’t working on one side.
