1 - 20 of 34 Posts
See above + car towed to shop. Can't figure it out. Towed to good tranny guy. No go. Towed back to shop. Keys cloned attempted theft window broke. Towed to tech guy. Removed cloned key cannot sync mine tho. Towed to dealer. 2 months. Cannot figure it out. 2016 set hellcat Challenger. Need competent North Jersey Shop! Dammit!
Car originally towed due to all of the sudden neutral. No gear at all. Then stuck in park completely. That was the start. The attempted theft from shop musta pissed them off because the car won't drive. Lol, but even Ramsey Dodge cannot figure out the tranny issue. A dealer that doesn't know? I need advice.Thx
Thats crazy i find ramsey dodge to be pretty competent so far, wish you best of luck my man.
Is there a sensor for the gear selector that may not be working properly? Maybe pull the center console top and look for a sensor around the gear selector lever. Also look for the sensor that senses the brake being depressed so you can put it into gear. Sounds to me like it is something simple like one of those.
Discussion Starter · #11 ·
Thank you very very much for that. It does feel like it was something stupid and not a thrashed tranny or valve body. No noise whatsoever when it went. Nothing! Thanks for taking the time to reply I appreciate you..
Anytime bud. Please keep us informed if you figure it out, or still have issues.
See if these help (the youtube is for a Ram, but it's still a Dodge and may be relative)
2016 Challenger Hellcat Pitch Black A8 (1 of 16,426)
Make sure the manual park release lever is all the way down. Also check to make sure the linkage on the drivers side of the transmission isn't jammed or cable bound up.
  • Check that the system operates smoothly from the lever inside the vehicle.
  • Check that the cable is properly routed with no sharp bends or kinks.
  • Check the levers at the operator end and transmission ends for any obstructions that could prevent full range of movement.
  • If necessary, disconnect the MPR cable from the lever at the transmission to isolate any conditions found.
1 - 20 of 34 Posts
