Upper or Lower pulley?
12K views 14 replies 11 participants last post by  1Hellcat2Envy
Which one are you guys doing? Regardless you have to pin the crank but I like the fact you can swap pulleys out. Just not sure if you pin the crank with the stock damper pulley how hard is it to swap out later for the 10% OD pulley?
#7 ·
I plan on doing the Crank Pulley and the biggest reason is that you need to pin the crank anyway so while I am there, I will change the Crank Pulley. Then at a later date, if I choose, I can also change the upper pulley and retune.
#9 ·
Rick
Thanks for the pulley, we set a few records last week using the combination of the two, METCO and ATI, if you are not going to max out the boost then the METCO is the one you want , it is very easy to change out and has a few optional sizes, the question being tossed around is do I pin the crank? if you pin you void the warranty.... but if you play as hard as we do then it's a must as we don't care about the warranty.
TC
#10 ·
Topcat I think I am going to go the Metco route as well as pin the stock crank pulley for safety. I will have HHP provide a tune and call it quits for me. I just want it to run in the 10's even when the heat is on.
#12 · (Edited)
As long as the standard O/D ATI crank pulley fits with out modification then this is what I intend to fit. I will pin the crank and add Rick's 2.75" top pulley. I'm not going through my Supercharger pain without coming out the other side with a little enhancement. My missus did say the other night. Don't you think the Hellcat is fast enough. I just looked at her with a slightly bemused expression. Okay fair enough she said :D
#14 ·
Rick do you I have the part numbers for the pin kits that are out there I know ATI makes one but there's also another one that pins from the end of the crankshaft snout that I like better.
Bam Bam
There are a few good sources for info and parts with regards to pin kits. I would start with Josh at HHP or David at Modern Muscle. Both have forums in the vendor section.
