1 - 18 of 18 Posts
· HOTY Winner
Yes, they are a very nice american made piece.
Reactions: Unholy707
I like mine. Tough fit, but a nice piece.
Agreed, no simple unscrewing of the can like the JLT mounted in front of the engine. I still prefer the UPR though.
Doesn’t look like it’ll be too bad to empty, just undo the turny thing and quick disconnect connect clips
I've found the easiest way for me is to take the thumb screw off and lift the bottle up where you can unscrew it. No need to unhook the hoses. You kinda have to free one of the hoses from getting caught on battery cable sometimes but its no problem. Count me in for another vote for the UPR products being very high quality. I ran the Z bracket one before the fender mount on both my '18 HC and '19 REWB. However once I had the interchiller SC spacers installed and a smaller upper pulley that required an idler pulley the Z-bracket mount sat up too high and hit the under side of my carbon fiber hood, causing me to switch to the fender mount. Im glad I did as it is an improved model over the Z-bracket plug and play I had.
The valve covers contain a built-in oil separator. Clearly the dodge engineers thought it was something important to do. A catch can just extends the system and gets even more of the oil out--any that the built-in ones missed. On mine the can has consistently trapped several oz between oil changes.
Ive never looked into it..... If oil gets into the intake, is that a good thing?
Sent from my SM-N950U using Tapatalk
A light coating of oil on intake is nothing to worry about.
I'd be more concerned after installing catch can If a connection breaks loose or vacuum seal fails. Don't count on your warranty to fix or replace engine.
Discussion Starter · #17 ·
Pssssh warranty lol. I have a high boost car. Catch cans and/or breathers are needed on high boost cars due to crank case pressurization.
1 - 18 of 18 Posts
