IAT reading shows in dash gage cluster. On Uconnect screen, not so much.
View attachment 587680 View attachment 587681
Yeah, I noticed it a few times. Like my Dell laptop, turn it off and turn it on again and it was working again....except the last time. I'll try the fuse. Thanks!Yeah, 'dashed' values occur infrequently and usually reset on the next Run Cycle. If it persists, pull Fuse F37 (Radio) from the Battery Fuse Center for 30 seconds.
Experiencing the same issues with ICT. I’ve tried it all in attempt to reset; however, YMMV. View attachment 587688
No. I was about to do that when it came back on.Is this after pulling the fuse?
The I/c temp is actually the iat and iat is actually I/c.Their location on the screen or the wiring for the sensors? Or both : )
Screen. Gauges by speedo is accurate. Dodge screwed it up with an update and refuse to fix it.Their location on the screen or the wiring for the sensors? Or both : )
Yep smh.Screen. Gauges by speedo is accurate. Dodge screwed it up with an update and refuse to fix it.
What's their excuse for refusing a fix?Screen. Gauges by speedo is accurate. Dodge screwed it up with an update and refuse to fix it.
Ask @DodgeCares . I have no clue. Assume they don't want the risk of more bugs. I just hope they add that fix to the update when the security update makes it down to the 15-17 cars.What's their excuse for refusing a fix?
