I would give
High Horse Performance a Call Sales @ 1-888-894-1115
Joshua Schwartz is at the track with his Hellcat customers into the 8's. They are Testing + Tuning / R&D for the Built Transmissions. This is why you would want to have the advice from one of the most Knowledgeable and Experienced Speed shop in the Country. Everything Hellcat Started out of HHP. I know, because I was there in 2015 with my Husband
@Top Cat and Josh. We together went to the track 3Xs a week for T&T and R&D of parts and Tuning. Josh continues to spend time at the track with many of his customers and vendors to contiune to bring the Best of Everything Hellcat!
SunCoast 8HP70 Rebuild Kit with Alto G3 Clutches - SC-216901PWR
highhorseperformance.com
This new Suncoast 8HP70 rebuild kit is manufactured using Alto G3® Material. G3® is a (non-asbestos) organic based friction material with impregnated carbon graphitic particles. Carbon adds lubricity and high thermal stability to the friction material. Through Alto's grooving techniques and proprietary processing, the friction material can be tailored within a specific friction performance range found within the natural limits described in the friction properties section.
This new 8HP70 kit also come with Alto G3 clutches and high performance steels. This 8HP70 rebuild kit also comes with the valve body molded gasket and a high performance rebuild kit.
This kit also contains the molded pan gasket and the rubber gasket and seal kit. This is everything you will need to have to do an upgraded rebuild on your transmission.
