I was going to start at 20 psi maybe higher on the rear and looking for input on the front. I have the stock wheels and tires. It will be western NY so still chilly. Also do you guys leave it in track mode?
Good point18-22 on the rear, start at 22 work your way down. Run fronts at max for least rolling resistance.
Hes talking about drag racing psi.Stock factory tires? What does the door placard say?
On an 18" rim idk about going further. Id call Nitto and see whatbthey recommend for NT05R.I start my drag radials at 18 and work my way down.
My NA 3V 08 Mustang was cutting 1.57-1.59 60’ on drag radials at 17psi.Hes talking about drag racing psi.
Waste of a pass the whole wold knows your going lower than 25. Take the dress off and run the car.You will want to watch for stability at the big end of the drag. Once you get too low on tire pressure, the car will become "floaty". I've run my street drag radials (MT SS, Nitto drag radials) at 18-22 psi.
I would maybe run 25 psi down the track the first run just to be sure the car is stable and feels solid. Safety first. Just roll into the throttle and make a clean run. Don't worry about cutting a good light or any of that. Just get your basic routine down. If you aren't consistent with that stuff then it's like shooting pool with a rope when it comes to tire pressure.
This dude constantly hating on the 17x10” beadlock wheel. Have we even seen pics of your car yet?Lol
Couldn’t agree more
Then again first time I threw my leg over a 8.90 bike I put it in the chip (8250) and threw the clutch lever and damn near killed myself
17 psi is too low unless you have a huge tire pinched on a narrow rim like the set up @Unholy707 just installed
Sounds like good advice. I like it. So just take foot off brake and try to don that a split se cod before the light ?You will want to watch for stability at the big end of the drag. Once you get too low on tire pressure, the car will become "floaty". I've run my street drag radials (MT SS, Nitto drag radials) at 18-22 psi.
Waste of a reply. The whole world knows you're going to blow the tires off on your first pass either way, ha ha. Just joking around.Waste of a pass the whole wold knows your going lower than 25. Take the dress off and run the car.
What’s your best time? Foot braking ?Waste of a reply. The whole wold knows your going to blow the tires off on your first pass either way, ha ha.
But yes, like German said, could just as well go 22 or so. You are going to be traction challenged either way. Just stick with it and get used to the car. I guarantee that your times will improve over the course of the day and as you learn the car.
On a side note, here's a pic of my car with 17x10 beadlocks on the rear. I think they look just fine.
The ONLY time I got squirrelly was with a 20" rim and RRRIIs at 20 psi. Since then I ran 17x10 MT Street Rs at 17 psi no wiggle. Then switched to Bias Plys at 16.5 no wiggle.You will want to watch for stability at the big end of the drag. Once you get too low on tire pressure, the car will become "floaty". I've run my street drag radials (MT SS, Nitto drag radials) at 18-22 psi.
I tried to tell themThe ONLY time I got squirrelly was with a 20" rim and RRRIIs at 20 psi. Since then I ran 17x10 MT Street Rs at 17 psi no wiggle. Then switched to Bias Plys at 16.5 no wiggle.
