Once the engine is started and running the battery supplies the current to the rotor to power the electromagnets so A/C electrical power is generated when the alternator is spinning.730CCA at 0F is big! Maybe you're thinking of just "CA" which is 0C; 32 F. Secondly, all it needs to do is start the car until the alternator kicks in.
^^Awesome !! Thanks.Agm/flooded is O.E.
I bought this same battery and it is great. Runs the cool down mode at the track well without fear of killing the battery.I replaced the OEM battery on my R/T with a Diehard Platinum AGM from Advanced Auto Parts (Part # H7-AGM) just a few months before I traded it in for my Hellcat. Comes with 850 CCA and a 3 year free replacement guarantee.
When I signed the deal for my Hellcat, one of my provisions was to swap out the OEM battery (which I guessed to be at 6 years of age and was probably nearing its end) with the almost new Diehard from my R/T.
Aren't AGM and flooded two different types? I thought flooded was the typical lead acid and AGM (absorbent glass mat) is called dry cell?Agm/flooded is O.E.
Had a corvette that would drain them out , I just keep everything seldom driven on trickle chargers.My die-hard was left for a month, completely discharged, forever dead. I will never buy another. It was only a couple months old, and this was in spring-to-summer weather.
NOCO makes one that will charge/manit them and it knows what it isAren't AGM and flooded two different types? I thought flooded was the typical lead acid and AGM (absorbent glass mat) is called dry cell?
I have always used battery tenders on my challengers, set up for normal lead acid batteries an have never had a problem. Unless something has changed recently with the batteries supplied I assume they're still the same. Just don't want the OP to get incorrect information. The AGM batteries do have different charging / maintaining needs and you don't want to mix up chargers.NOCO makes one that will charge/manit them and it knows what it is
Right , what I meant was the charger recognizes what it's connected toI have always used battery tenders on my challengers, set up for normal lead acid batteries an have never had a problem. Unless something has changed recently with the batteries supplied I assume they're still the same. Just don't want the OP to get incorrect information. The AGM batteries do have different charging / maintaining needs and you don't want to mix up chargers.
Agreed, those are great. Looked like the OP might already have or be buying a charger that is manually selectable.Right , what I meant was the charger recognizes what it's connected to
