depends on the driver mod...
the brace will definitely take .7 - 1.5 off your et....oh, and yea... that brace, may have voided your warranty. fyi.
there is not point to mod if you're worried about your warranty.
lol I’m getting better as a driver still learning the car that why I’m trying to get all the infodepends on the driver mod...
So the brace and tires will have me running what?????depends on the driver mod...
Do you take traction control off when you do lone lock?depends on the driver mod...
Best case scenario what can I run with those two thingsAs I’ve learned, its all down to the driver
your diff brace has ZERO to do with your ET. your tires will only net you better times if the driver mod knows how to use them. if you're lucky you may come within 1.5 sec of dodge's listed ET. racing on the track is nothing like racing on the street.Best case scenario what can I run with those two things
No shit Sherlock hate to tell you you were new once too I don’t need a breakdown scientifically I just need a roundabout numbers to know if I’m doing good or notalso depends on track prep, weather & current DA..... just goto the track. bring back a time slip and post it. then ask questions. with your lack of research on here and lack of knowledge best case scenario is not going to be achievable as it sounds like you've never been on the track based on your noobish questions.
that was my first 2 times at the track. Just trying to figure the car out. Obviously I had a hard time hooking up with the all seasons and I was trying to figure out all the different options so yeah putting it all together isn't impossible.also depends on track prep, weather & current DA..... just goto the track. bring back a time slip and post it. then ask questions. with your lack of research on here and lack of knowledge best case scenario is not going to be achievable as it sounds like you've never been on the track based on your noobish questions.
I thought the brace would cut down on the wheel hop wouldn’t that make your quarter time faster?your diff brace has ZERO to do with your ET. your tires will only net you better times if the driver mod knows how to use them. if you're lucky you may come within 1.5 sec of dodge's listed ET. racing on the track is nothing like racing on the street.
Not 100% true. But I get your point. I just wanna know what I’ll be able to achieve with those two things best case scenarioAs I’ve learned, its all down to the driver
Give Don garlitz a Prius and I’ll beat him in a hellcat 😂Not 100% true. But I get your point. I just wanna know what I’ll be able to achieve with those two things best case scenario
obviously I’d be happy to get in the tens. Friday it will be low 60° outside in western New Yorkalso depends on track prep, weather & current DA..... just goto the track. bring back a time slip and post it. then ask questions. with your lack of research on here and lack of knowledge best case scenario is not going to be achievable as it sounds like you've never been on the track based on your noobish questions.
