Hey Gents.
I’ve ordered 6mm wheel spacers all around for my Widebody Charger as I’ve read the wheels can still come out a bit further to be flush with the flares.
My question is : what is the appropriate amount of spacer for the stock wheels to come out to the edge of the flare?
6mm in front?
I’ve read it’s more in the rear? If so- what’s required - longer studs and a hub centric 8mm or 10mm spacer?
The speed Logix 6mms are the max you can do without having a hub centric spacers (there is just barely a lip on sticking out for the rim to center)
I’m okay with making the investment in longer wheel studs and proper spacers if the rears needs a thicker spacer.
Any product suggestions welcome.
6mm in front?
