20x10.5 ET 20 is what clears the front sir, so either way in this case a 5 mm spacer is used to clear the front brakes.
I'm pretty sure my PK Auto 20x11 rears have a 27mmThanks for your response, what is the optimal offset for a set of oem replica wheels?
No.So the more positive offset the more it sets back into the car. I have the 305's mounted up. Keeping the same offset at 18.5 mm with a wider wheel keeps the tire in the same realitive place.
True, all four wheels/tires on OEM interchangeable.I've read through this entire 5 paged Post/Topic and I don't see anywhere, someone sharing that the Front Offset of our Stock(2016 Chllngr Cat) has a different Offset than the Rear. So, they are the same I must presume?
