Does it not have to be strapped down in a certain direction for the accelerometer to work properly? I assumed, and the OP may have as well, that it is directional specific and needs to be mounted, kind of like a trailer brake controller.I have mine in my sun glass holder
It has to be mounted on a level surface(or very close to it) with the top of it exposed to the sky so it can read the GPS signals.Does it not have to be strapped down in a certain direction for the accelerometer to work properly? I assumed, and the OP may have as well, that it is directional specific and needs to be mounted, kind of like a trailer brake controller.
Ok, so it's all GPS satelite based and no accelerometers I guess, I didn't realize that. I did a little reading and it looks like they come with an adhesive backed metal strip that you could stick on the dash or rear deck maybe. You may be able to set it up right behind the headrest on the rear deck to where it is hardly even noticeable. Did yours come with that strip? I'll have to open mine and see if it has one.It has to be mounted on a level surface(or very close to it) with the top of it exposed to the sky so it can read the GPS signals.
Sunglass holder won't work, or if it is taking readings there, it can't be the most accurate (poor GPS reception and not level)!
An ideal place would be under the front or rear window. Just that I'd have to use velco or something, there is no metal object there....... On my GTO I could stick it to a speaker grill in the rear and it worked perfect.
I'm sure you can also mount it outside on the fender or roof or something, but I'm not risking it flying off.
Not sure my bro gave it to me, I don't have the original box for it. I just have the actual dragy. It could come with extra mounting hardware not sure. I'll either get a suction cup mount like posted above or I'll double side tape it somewhere......Ok, so it's all GPS satelite based and no accelerometers I guess, I didn't realize that. I did a little reading and it looks like they come with an adhesive backed metal strip that you could stick on the dash or rear deck maybe. You may be able to set it up right behind the headrest on the rear deck to where it is hardly even noticeable. Did yours come with that strip? I'll have to open mine and see if it has one.
