Hey all, I have a 2019 Challenger Redeye that recently started making a whiny noise when I close the door with the window all the way up on the drivers side (passenger side operates normally with no sounds). As you know these are frame-less windows so they go up and down automatically with the door opening and closing. This only happens when closing the door and not when opening or rolling the window down regularly. Anyone know of this issue? Is the window motor going bad? I'm still under warranty so should I just go to the dealer and have them look at it?
Have a listen below, thanks!
