1 - 5 of 5 Posts
All,
I just wanted to post this real fast. While I dont have a bunch of info yet, I reached out to Dustin Whipple on linkedin and let him know about the issue I have had with the whipple. If any of you have noticed that the air box it ships with for the Hellcats with the gasketed air box ( 2019+), you'll find that it does not seal as it is concave where the factory set up is a flat surface. Lets heat in and sounds weird. Also, in my case I have been getting P012B codes for the by-pass valve getting stuck open. In my case it almost caused a semi-trailer to run right up my back side as I was merging on the the freeway.
That said, Dustin Whipple was very responsive and helpful. Once I get more details from them I'll share here. Maybe Whipple staff will have some ideas.
Thanks
Just picked mine up from my builder today. He said at first it hit the hood at a bad angle and caused the hood to slightly bow up in the middle. He modified the housing slightly and now it’s a perfect fit. I’ll get a pic of it tomorrow if I have time.
1 - 5 of 5 Posts
