1 - 11 of 11 Posts
Car was built late Feb 2020, has 700 miles on it.
I realize its aluminum corrosion and normal but it is really thick on the diff and trans brace.
I am also sure it does not hurt anything but I am a total freak when it comes to my cars.
Some will scrub off with a towel, some will not.
Any ideas on how to remove it (without a wire wheel) and how to seal it so it does not come back.
Or should I just get over it?
Thanks for your time,
I think you would need to wire brush it and then clear coat it to prevent it coming back. But then when the differential fails they would probably void your warranty.
Spray it down with WD 40 once in a while, it won’t be shinny like it’s polished but it will keep the oxidation down
Mercruiser Corrosion Guard works great too.
Reactions: 2fast4u
Some of my cars came with some kind of undercoating applied. Representative of what this looks like here is a pic of part of the bottom of the engine/oil sump plate of my 2008 Cayman S:
All the brown coating is some kind of undercoating/corrosion protection applied at the factory. All rear and front suspension hardware was "treated" with this stuff along with as pictured the engine, transmission.
Looks like Cosmoleum
Its oxidation they all have it..especially if car was transported around winter time with brine on the roads etc.....carry on :)
I know "it" as "cosmoline" but maybe "cosmoleum" just a different name for the same thing.
Or not. I searched cosmoline and got lots of hits and all dealth with its corrossion protection or how to remove it -- I used diesel fuel to remove it from machine tools arriving from overseas -- but when I searched cosmoleum the first hit was this: "A Cosmoleum℠ is a celestial resting place for the symbolic distribution of cremation ashes."
Put a Dif. brace on and you won't see it. Unless you crawl under the car. Or blow up your Dif. and get a new one before the warranty runs out.;)
@Rockster..You are correct it is Cosmoline. I had a brain fart and couldn't think of it so I thought it was close..LOL
1 - 11 of 11 Posts
