I think you will make itSoon to get tuned in two weeks... car has cat delete muffler delete lmi intake 100mm throttle body and ported snout. Stock pulleys. Upgraded coils. What do u think I’ll make. I do use custom mix of fuel
Redeye, or regular Hellcat? If just hellcat manual or auto? Without going up on boost your not going to gain a whole lot unless you plan on using a high octane fuel like 110 and give it a bunch of timing but be careful there as one bad detonation event will ruin your day. DONT desensitize your knock sensors, their going to be your only savior.Soon to get tuned in two weeks... car has cat delete muffler delete lmi intake 100mm throttle body and ported snout. Stock pulleys. Upgraded coils. What do u think I’ll make. I do use custom mix of fuel
The thing about building cars... it's all governed by the laws of physics. If you have a container that can only hold X amount of volume... if that container is full, trying to put more stuff in it with a larger funnel (throttle body) isn't going to do anything. In stock trim, the Hellcat's throttle body is already more powerful than what the car can use. If you don't believe me, have your tuner show you the throttle body settings in the tune and note how the factory setting has it set at 75% max open.I’ll post up my dyno sheet when I have it.. no way my car is running under power if I pulled on a red eye 😂
Thus, putting a larger throttle body on a car with stock heads and a stock blower is a grandiose waste of money. That's because, coupled with injectors you don't need and higher octane fuel you don't need, and the result is the computer is literally dumping that stuff right into your catalytic converters.
Now, if you add components that requires the additional flow and octane rating, that would be a different story. Higher octane does not = more power. Not on cars made for 93 fuel. The higher octane is needed for reducing knock under high compression. So, if you are running a pulley, you can run higher octane instead of doing an E85 conversion. The only problem with that, is the fuel is about 5x more expensive and you have to have a very good tuner to tune the engine for high octane or, quite literally, KABOOM at WOT. FWIW, 104 octane for me is about $14/gallon. I have a race car that runs on it. Expensive stuff.
Every mod you listed is reducing horsepower and efficiency on an untuned stock component vehicle. So, if you pulled on a Redeye, they lifted or something. The adaptive PCM in your car is simply adjusting timing for the rich environment you're creating so that it runs within expected parameters. Without the tune and without actual mods, the car is making no gains at present. For example, the LMI is a good intake, it's just that the Hellcat isn't an NA or intercooled car and a reduced IAT does nada since the air mass is after cooled. Folks like us with aftermarket CAIs do it for the sound, as they don't produce any HP whatsoever.
Yes, that’s rowing your own with a 5000 lb with me in it full tank of gas floor mats, all the seats, trunk liner, nothin ever removed from the car just crap added super docil easy to drive idles like stock clutch feels like stock looks like new 9 second whale yes.So you have 900whp and run 9.9?
Looking forward to see what your car is making.E98 is good fuel. I use ignite in my evo. For sure your car is one bad machine. What state do you live in. I took my hellcat to the track dead of summer here in Az it did good for the weather humidity and da that day I broke off 11.4 @ 122 no launch
I went with a Demon clone cam, wishing I went with the bigger cam I had in hand at the time as I’m not moving much more air now then I was with the stock Hellcat cam. I will say though the smoothness and drivability of this cam is unbelievable. I’m playing with different cam timing tunes now for the time being. May be changing to a Cam Dynamics PD .630 lift cam over winter and Johnson lifters.Looking forward to see what your car is making.
16GoManGoHC, which cam are you running? I have an EMP cam and I’m making 880rwhp but 950rwtq. I was hoping to be at 1000+rwhp but the shop said that’s the most they can squeeze out of it with this cam.
