It’s an aftermarket kit from vicrez everything going well so far haven’t done any cuttingNice. Is that OEM parts or aftermarket kit?
Sadly they only make Phillips flares for challengers. Us charger guys are stuck with oem or Vicrez which I’ve heard many people have issues with. And going oem requires modification to the quarter panel it isn’t as easy as modding the challenger quarter panel.Nice. I got the Phillips performance stuff. I’d do that or factory, that’s it
Wha? Just take a cutoff wheel to itSadly they only make Phillips flares for challengers. Us charger guys are stuck with oem or Vicrez which I’ve heard many people have issues with. And going oem requires modification to the quarter panel it isn’t as easy as modding the challenger quarter panel.
Just a heads up. Assuming you are getting the wider rims/tires for that widebody kit, you may run into issues with the wheels hitting the OEM fenders going over deep dips or bumps with them sitting further out. Some have reported this in other forums.It’s an aftermarket kit from vicrez everything going well so far haven’t done any cutting
Yeah I went with the vicrez wheel they are 20x11 -2.5 offset and I went with a 305 30 tire instead of a 35 some people were having better luck with the 30 than the 35 but hopefully all goes well if not I’ll report hereJust a heads up. Assuming you are getting the wider rims/tires for that widebody kit, you may run into issues with the wheels hitting the OEM fenders going over deep dips or bumps with them sitting further out. Some have reported this in other forums.
If you looked at a challenger quarter panel vs a charger quarter panel without the flares on them you’d understand what I mean.Wha? Just take a cutoff wheel to it
Bump, done yet?
Yes it’s done just having some issues with rubbing I didn’t cut anything but I got some springs to raise the car back up that should solve that issue otherwise perfect
