10.5 inch is all you need. The 305s won’t rub. Do a search on this sight and you’ll find everything you need.
Well when you put it THAT way…But what if we do need 1,000,000,001 threads on it????
Ok so if I were to run 305/35/20s on the rear with 10.5, As long as I matches the 35 for the fronts would I have any other issues, as compared to the 40s10.5 inch is all you need. The 305s won’t rub. Do a search on this sight and you’ll find everything you need.
That explains why I got pulled over doing 90 in a 55 🙄What offset do you have? My 11”x20” wheels have a +22mm offset and fit fine with 305/35 tires. No pooch out beyond the fender either. Keep in mind your speedo may now be off a bit though.
The wheels I was looking at were 22mm offset, I read guys that went with 25mm had problems. The last thing I want to figure out is if I should go 20x10.5 or 20x11, as you said you have 20x11 without any rubbing, I wanna go with the 305 PS4S, which have a wheel width of 11 inches so I guess the 20x11 make sense. I’m just afraid of rubbing. Guess I wont know exactly until I try.What offset do you have? My 11”x20” wheels have a +22mm offset and fit fine with 305/35 tires. No pooch out beyond the fender either. Keep in mind your speedo may now be off a bit though.
The 11” set me up for 315’s but I chickened out and went 305’s to be safe. 305’s are a nice fit on 11" IMO. The 315’s were only a quarter inch wider anyway. I’m lowered so did a Bwoody kit to get the camber dialed in and still no clearance problems.The wheels I was looking at were 22mm offset, I read guys that went with 25mm had problems. The last thing I want to figure out is if I should go 20x10.5 or 20x11, as you said you have 20x11 without any rubbing, I wanna go with the 305 PS4S, which have a wheel width of 11 inches so I guess the 20x11 make sense. I’m just afraid of rubbing. Guess I wont know exactly until I try.
