1 - 13 of 13 Posts
I just added 345/30/19 rear tires to my 2016 HC. Stock size for vipers if I am not mistaken. Any heard of or seen any wider? This size is slightly shorter as you can see in the pictures. I did this for gear ratio reasons because I plan to run a 3.09 differential. Wheel size is 19x11 not sure of the back spacing or offset since I bought them used. They stick out (poke) a tad but I don't mind. If I had a widebody HC it would be perfect. I plan to lower it later to get rid of the fender gap.
20200625_094125.jpg 20200625_094146.jpg 20200625_094308.jpg 20200625_094315.jpg 20200625_113637.jpg 20200625_113652.jpg 20200625_113727.jpg 20200625_113742.jpg 20200625_113800.jpg 20200625_113806.jpg
HOTM Winner
2017 Challenger SRT Hellcat
Are you road coursing with that 345 tire ?
That's not bad as far as sticking out past the fender , my 20x11 wheel with 315's are about the same.
Discussion Starter #3
My main thought was for drag racing. I wouldn't take RR off the table though.
305/30/20s are going up front later. Seems like an appropriate staggered size for the pair.
HOTM Winner
Sounds good , but I think those 345's are more for RC not drag racing , but they may do good for that too ?
GL & have fun.
345 is the widest tire I know of that will fit on the back of these cars with a custom offset wheel. Most people get them in 345/30/20 though.
Discussion Starter #6 (Edited)
Thanks for the info. I hadn't considered looking up the 20s since I don't have wheels to mate with them.
I got the wheels used and a great deal from a guy who was trying to run them on a BRZ. So that's one of the reasons I went with 19 instead of 20.
345/35/19 would be much closer to stock diameter, but there are far fewer choices to pick from if you can find any at all.
Nitros in 345 run about as wide as Michelin or Goodyear 305s. They should work fine on your car.
Looks thick..🙂 Awhile back I was blasted for thinking of putting a 345 on my widebody 20x11 wheel..
Discussion Starter #9
So, one caveat I will mention here when running either wider tires/wheels or smaller diameter wheels. Make sure nothing rubs!! I checked to make sure nothing was rubbing but apparently I did not check thorough enough. It's common for the wire that comes off of the strut for active dampening to be way longer than it needs to be. When I checked for rubbing I only listened and felt for any catching that would indicate rubbing. That wire rubbing on the tire and wheel did not alert me on either test and now I need a new strut because that wire is not an independently serviceable part. Lesson learned.
Ouch.
You'll love the 345 in the rear! Im running Triumph 3 piece forged rims,
11.5 up front with 12.5 in the rear with PS4s tires. No rubbing at all, also no poke over stock.
557692
557693
Discussion Starter #12
That's so awesome!! Yeah, as soon as I put them on my car I was thinking this would be perfect on a widebody car.
1 - 13 of 13 Posts
