1 - 10 of 10 Posts
I’m getting a vibration in the steering wheel with light braking at highway speeds. I just had the tires road force balanced with no luck. I’m betting rotors are warped. Will Dodge cover a rotor swap in the first 12 months?
Actual warping of the rotors is rare. (To confirm it is warpping you need to measure the radial/axial run out of the rotor surfaces.)
What probably happened -- it happened to me with another car -- is you subjected the brakes to an event in which (uneven) material deposition from the pad to the rotor occurred.
In my case this happened when I washed the car and let it sit overnight with the brakes wet. They rusted of course and in fact froze up and emitted a noticeable "pop" when they broke loose when I went to use the car. I got on the road and was going down the highway at speed -- legal speed -- when I had to make an emergency stop to avoid a stop light runner. I got the car stopped in time. I left the brake pedal applied.
Afterwards I noticed a mild vibration/pulsing when I used the brakes. I tried bedding in the brakes (again) but it didn't help. The dealer refused to do anything about the condition. And maybe rightly so it was operator "error" not a brake rotor defect.
I found if I used a slightly more aggressive braking technique the pulsing didn't occur. I drove the car to 150K miles and on its original brakes, too. Had just about forgotten the issue but when I let a prospective buyer test drive the car she of course used very light braking and the pulsing showed up. She still bought the car but I made a slightly downward adjustment to the price.
In your case if you can't "eliminate" the symptom by changing your braking technique like I did -- and change was not dramatic -- you are faced with either having the rotors turned or replaced.
Discussion Starter #3
The first thing I tried was the hard braking to clean off any deposits, no luck. I even changed pads. Slight improvement but the judder was still present when lightly braking between 65-75. This was before I had the tires rebalanced. Pulsing only occurs between 65-75 mph with light braking. Yesterday, I got the car up to 100mph on the express lane (yes I know I’m breaking the law at those speeds but there was not one other car on the toll road) and when I hit the brakes to slow down it pulsated like crazy for a a couple of seconds. That’s why I’m curious if Dodge will cover rotors within X amount of months from new.
Challenger SRT 426
I’ve heard of them being replaced early under warranty. Just need to prove and document. The dealership will be your final decision maker.
If the problem is uneven pad material deposition hard braking -- break bedding in like hard braking -- will not help.
If the problem is warped rotors hard braking will not help either. Resurfacing or replacement is the only options I know of.
You need, the dealer needs to determine what is wrong. If it is warping of the rotors that should be something the warranty should cover.
Added: If the problem is uneven pad material deposition and if I as I suspect the dealer will not address this under any warranty and if it is not too bad you could try using a coarse emery sanding disc to rough up the brake rotor surfaces. You do not remove any material you want to simply rough sand -- the coarser the grit the better -- the rotor surfaces doing this in a uniform way.
Then take the car out and do a brake bedding operation. If you did things right -- and have a bit of good luck -- the pulsing should be gone.
The above assumes you have a suitable disc sander -- electric or air -- and the setup to lift the car and the ability to safely remove the rotors and rough sand them. And of course to properly reinstall the rotors.
You can sand, grind, machine, bed, polish rotors till you're blue in the face. It won't last and is a waste of time. The real and best fix is replacement. Unfortunately rotors for these cars are quite expensive unless you go aftermarket. I would definitely try and get them replaced under the 12/12 warranty, if that turns out to be the issue.
Probably right but it gives one something to do until one is willing to bite the bullet and resurface or replace the rotors.
Discussion Starter #9
This is what I’m shooting for. I’ve had rotors turned in the past and the vibration almost always comes back. The one thing I did notice, the pulsing was most noticeable after the rotors/pads were “at temp”.
I think vented/slotted rotors can't be turned. They need to be replaced. If your SVM is good to you he can get them covered.
1 - 10 of 10 Posts
