I was prepping the car for drag racing tomorrow and noticed these diagonal lines on the sidewalls of both rear tires. The diagonal lines are all the way around both tires. They are Mickey Thompson 305/45-17 ET Street R Radials on Forgestar single beadlocks. I run them at 20-21 psi at the track and 30 psi when driving to the track.
I also noticed that they have spun on the rim about 4" on driver side and 2" on passenger side. I have kept the beadlock bolts at 144 in/lbs (12 ft/lbs).
My 60' times are typically high 1.5's to low 1.6's.
Any thoughts on if this is normal and any reason for concern?
