Pocking tire hitting fender?
2.8K views 5 replies 4 participants last post by  TrackDay
Do you know any stories of poking wide rear tires hitting and damaging fenders?
I have a regular body HC Challenger with 305/35 R888R just installed in the back; the wheel is 11" and the offset is 19 mm. The R888R run wide and in 305 they are as wide a many 315 tires. So the result is that the tires poke out about ~1/2 inch or so. I can see that they won't clear the fender if they can reach it.
So the the question is: is this safe? I see a lot of regular body Challengers with rear tires pocking out (or with Lil' Devils fender flares). Do you know of anyone actually damaging their fenders on a bump or whatever? My car is not lowered, stock suspension; there is about 2.5 inches clearance between the top of tire and the fender when the car is empty.
#2 ·
I put about 800lbs in my trunk and the rear end dropped about a quarter of an inch. I think you'd have to hit something pretty hard for it to sheer something. 20x11 PK Auto replicas 315/35 Nitto NT05s.
#3 · (Edited)
^^^ I have 305 Conti’s on 11” wheels with to issues. Car is lowered a fuzz over an inch too. My offset must be in tighter. Not sure what mine is. Velgen just sent these knowing what car I have.
I’ve since had a suspension kit installed to dial in the camber but still didn’t poke the tires out much more than in these pics.
#4 ·
If you need the offset I can find it, but it's whatever PK auto BIG brain guys figured out. I never had any rubbing either. I ran Nitto NT05s 315, NT05Rs 315, and 555s 315 with no issues but I did get a few people asking if I was worried about a bad pothole (we have potholes here that require spelunking gear to retrieve unwary joggers who fall in) that it would shred a tire. Also, because at full compression, due to camber, I don't know if they would even touch.
#5 ·
That's not too difficult to figure out: I have a bunch of cheap crappy spacers that I can play around with to see how the tire sits. 21 mm seems to be the limit without the risk of rubbing at 3 o'clock against the metal parts. If I take a sledge hummer to those pesky ribs at 3 o'clock, I could probably get away with 23-24 mm offset, but even in this case the tire will stick out a bit.
I raised the back of the car on both sides (that's the only way to do it with these cars IMO), put a cinder block under one of the rear tires, and lowered it. The opposite rear tire was handing in the air, but I didn't get the full compression. The top of the tire ended up a bit over 3/4" from the edge of the fender, and it was obvious the it won't clear it even with camber (at least on my car: different cars may have different camber).
