Question about Griptec pulleys
21K views 31 replies 11 participants last post by  TeamDemon
I was on the fence about a griptec, as a lot of people say its superior to the metco in terms of slipping. I was doing some thinking, and maybe my logic is way off (it very well could be) but wouldn't a non clutched pulley that stops INSTANTLY with zero slip actually put more stress on the blower and crank than the Metco. I know slip isn't a good thing, but when you going from a stock clutched setup to a non clutched pulley, wouldn't that slight bit of slip help relieve from stress over a dead stop?
#4 ·
I’m not. I don’t believe belt slip is beneficial in any sense of the word. All boost mods should have a pinned or keyed crank pulley. Having that takes the lower half out of this equation. As far as the blower snout and bearings go.... I think that increased belt tension trying to reduce slip is not a good thing all the time (not just off and on the throttle) and allowing it to slip as a kind of poor mans blower stress relief is (I’m just going to say it... sorry) halfass. I say go Griptec or put a Liten on it. I will not run a screeching Metco with the additional idlers and tensioners to try to get it to work right.
#5 ·
View attachment 520967 I’m not. I don’t believe belt slip is beneficial in any sense of the word. All boost mods should have a pinned or keyed crank pulley. Having that takes the lower half out of this equation. As far as the blower snout and bearings go.... I think that increased belt tension trying to reduce slip is not a good thing all the time (not just off and on the throttle) and allowing it to slip as a kind of poor mans blower stress relief is (I’m just going to say it... sorry) halfass. I say go Griptec or put a Liten on it. I will not run a screeching Metco with the additional idlers and tensioners to try to get it to work right.
That was actually the right analogy. Again, poor mans version or not, being that it’s a version would mean it’s still sort of better than not doing it at all isn’t it?
Not debating you here at all either. I was about to order the geiptec, then my usually over thinking came about and this thought popped in my head. Now I’m wondering do I just bite the bullet and go litens up front.
#9 ·
I think the Litens 2.72 is questionable for reliability. I am trying to find some solid info online to clear up my confusion. Is Hellraiser with Litens logo a real Litens made pulley? The reason i ask is my stock Litens is stamped "made in Germany" 2.72 is stamped made in "Canada" seems a little odd. I do have a good reason for my concern. Just not aware of who i should call to get info.
#17 ·
View attachment 521583 Here is dyno graph of tune day on my M6 with a Litens 2.85 on pump 93. Stock verse 2.85 with ID1050x
Love it!!
Thanks for posting. What was the reason for changing the injectors? Was the tune particularly aggressive or something? Perhaps others are leaving out the injector swap, but most to the Hellraiser installs and mentions about seem to be just the pulley and tune, right?
#20 ·
#23 ·
#26 ·
I guess it's that IAT that's the killer. I ran 100mph in the 1/8th yesterday in 2650 DA with just CAI and canned diablo tune. My IAT was only in the 130's though.
This post has been deleted
