So at 3k miles I started burning 3qts there's nothing on the dipstick dealer says 2qts and says normal but will monitor for 1k miles
At 4k miles same thing nothing on the dipstick we argue as to how much I'm burning and they mention a TSB that 2qts per 1k miles is normal for high rpm. I tell them I've never gone out of "street" car is too loose on the street and too stiff in sport or race so shifts point are not high rpm for street. Said will monitor..
At 5k down again said there was a new procedure dodge is changing to many engines dealer says 3-4 per wk at his dealer alone (various models)
Hit 5,750 get a MIL light engine running rough I get off the highway and shut her down again nothing on the dipstick car is very hot. Waited 4.5hrs for a tow through dodge roadside in 100deg heat
Dash had P1524 error code
I'm thinking engine damage but dealer is saying clogged PCV valve and wants to change it put oil in it and give it back to me. I argue and than dealer said engineer coming for a separate issue tomorrow and will have him look at mine.
Anybody know about any issues with PCV system clogging on HC's? I mean I have super low miles there shouldn't be any gumming up related to oil. Especially since I am having a lot of it burning and a lot of new oil put back in.
Thoughts of condition of engine after this event? I had low oil pressure that fluctuated so I think I was sucking up air and oil since pan was probably almost dry.
Diagnostic email below:
ALERT: Your 2015 Dodge Challenger SRT has detected an issue that requires your attention.
Attention is required for two issues. For more detailed information, click here to view the complete report.
No Issues Found
Action Suggest
Immediate Action Needed
POWERTRAIN
Malfunction Indicator Light
Your vehicle's Malfunction Indicator Light recently indicated your vehicle needs service. WARNING:Prolonged driving with the Malfunction Indicator Light on could cause damage to the engine control system. If the Malfunction Indicator Light is flashing, severe catalytic converter damage and power loss will soon occur. Have your vehicle serviced at your dealership immediately.
Charging System Warning Light
Electronic Throttle Control Warning Light
Transmission Temperature Warning Light
OIL & FLUIDS
Oil Pressure Warning Light
Hot Oil Warning Message
Oil Change Due
A “Change Oil” or “Oil Change Due” message has recently been displayed in your vehicle. Change your vehicle’s engine oil and filter. Schedule a service appointment at your dealer today.
POWERTRAIN
OIL & FLUIDS
