Has anybody tried the Killer Chiller from Kincaid Performance? The Mustang guys seem to really like it. Claim 40 to 50 HP thru cooler intake temps and less timing retard. Now making a Hellcat kit.
I remember that as an ice tank for cooling down the LTR fluid. That was purely for track use.
I think you are talking about the after run cooling just using the radiator fan to cool things down. That is not the chiller function.Or just use a tazer, since the beta version shows it cooling down the intercooler like the demon does
You may be right to an extent... like where the tazer allows you to "cool the intercooler". I don't know if I agree with "like the demon does".Or just use a tazer, since the beta version shows it cooling down the intercooler like the demon does
It isn't possible to jump a relay to run the I/C pump manually because it requires communication and signal from the PCM to operate. Folks have tried and this is the generally accepted result. Wasn't possible before but now it is with the Tazer beta version.If you didn't want to use the tazer, I'm pretty sure you could jump a relay to run the I/C pump off of a switch or just the jumper itself while you're in the pits.
I'm confused, are they making their own custom "Killer Chiller" cooled by the car's A/C system or are they just adding an ice tank or doing both? Call it what it is. An ice tank is not a Killer Chiller as that's a product name generally used to refer to a cooling setup that uses A/C. They both serve the same purpose though through different methods.My local shop MeraMotorsports is currently building a killer chiller kit with a 2 gallon ice tank for a cat that made 950whp with a 50 shot. They just upgraded the fuel system and are headed for a 100-150 shot with it hoping to make 1100whp. Stock motor, pulleys, 1300's on e85, nitrous.
The demon has two separate functions that sound similar. The After Chiller which runs the fans and intercooler pump while the engine is off and then it also has a drag mode Chiller that cools the intercooler coolant with the car's A/C system while the engine is running. The first feature is mimicked by the latest Tazer update while the 2nd is essentially what the Killer Chiller is made by Kincaid.The Demon uses refrigerant and additional hardware to chill the coolant below ambient. There is far more technology and hardware involved in the Demon's approach than simply running a pump/fan that is already in the car. The Demon basically has an OEM Killer Chiller.
BothI'm confused, are they making their own custom "Killer Chiller" cooled by the car's A/C system or are they just adding an ice tank or doing both? Call it what it is. An ice tank is not a Killer Chiller as that's a product name generally used to refer to a cooling setup that uses A/C. They both serve the same purpose though through different methods.
Cool, thanks for clarifying.Both
Good to know.It isn't possible to jump a relay to run the I/C pump manually because it requires communication and signal from the PCM to operate. Folks have tried and this is the generally accepted result. Wasn't possible before but now it is with the Tazer beta version.
I'm 99% sure this wouldn't work without a bit of electronic trickery. The pump requires additional input to modulate the flow which is provided by the PCM. Without that input, it won't run. It's like a PWM controlled fan. Our radiator fan operates the same way, we can't jump our fan to turn on either with the engine off. Same deal with our electronically controlled active exhaust valves, can't jump that either.If not just jumping a relay, wouldn't any 12v source pig-tailed into the pump wiring do the trick? Not that anyone wants to hack into their harness, just a thought. I didn't think the Tazer was an affordable alternative to something that could be accomplished with some wire, wire ends, and pliers.
If you could document your install and create a thread on it, we could all learn from you! And, be very grateful!!!I just ordered a Killer Chiller for my Hellcat. Fun times ahead!
I'll do my best!If you could document your install and create a thread on it, we could all learn from you! And, be very grateful!!!
