Steering wheel vibrates between 75 and 80. Dealers have tried to balance wheels 5 times and have had a new set of tires put on but still have issue!
Thx Dan
Thx Dan
They have that system where I go ,they balanced all 4 with the replacement on the left front tire. However I noticed that 1-1/4 ounces of weight were used. I am going to work today at 3:30 pm ,I take the turnpike so I hope it is resolvedI definitely recommend the Hunter Road force balancing as recommended in prior posts.
It is very possible a new set of tires could have excessive ride disturbance as well.
Keep us posted with your progress and what happened.
Take care and be safe
Did they happen to give you any readings of specs or lbs they were out? Printout perhaps?They have that system where I go ,they balanced all 4 with the replacement on the left front tire. However I noticed that 1-1/4 ounces of weight were used. I am going to work today at 3:30 pm ,I take the turnpike so I hope it is resolved![]()
Thx Dan
Any updates on this matter? 3019 Charger HC that did the same thing. Got 4 new tires and still vibrates.Steering wheel vibrates between 75 and 80. Dealers have tried to balance wheels 5 times and have had a new set of tires put on but still have issue!
Thx Dan
