141 - 158 of 158 Posts
Disclaimer I built the motor to handle 1200+ but I am still on 93 pump, I drive this car daily so I wanted a reliable street car and when i want to turn it up I can by adding bigger injectors. I drive my Hellcat everywhere she doesn't sit in the garage. I drove it 4hrs away to HHP to have it retuned and drove back all in the same day and the blower did GREAT. Below is my setup and what it made on HHP's dyno. So if any is looking to add this blower here is something to look at and gauge. It cost me a little over $8K for installation and tuning
Current Step-up
2021 hellcat
Carrillo rods & pistons
HHP custom cam
HHP Dual fuel pump
HHP/ BES Ported head
ARP Studs
Springs & retainers
Kong 2650
Kong upper pulley
Nick Williams 108 TB
JLT Intake
1050cc injectors
Super damper balancer (OEM)
Stock Exhaust
93 pump gas
Car made
760Whp (3.50 pulley 13lbs boost)
874WHP (3.25 pulley 16lbs boost)
903WHP (3.00 pulley 19lbs boost)
Are you having any belt slip issues with the +3" pullies?
I have a Kong 2650 on the way and would like to reuse my 2.4IHI on another project car. Could you please confirm that if someone does not want to scavenge parts from their factory blower, they need to get the following parts:
  • IHI Supercharger Lid
    • 21x Supercharger lid bolts (5x long bolts in center of lid & 16x short bolts around perimeter of lid)
    • Lid gasket (#1 in the picture)
    • Green bypass valve gasket (#2 in the picture)
      • EDIT: Wrong gasket identified. It should be the green o-ring to the right.
    • Bypass Valve
    • Black donut gasket sealing bypass valve to the snout (#3 in the picture)
    • Green rectangular gaskets that sit underneath the lid (#4 in the picture)
  • IHI Intercooler Bricks
    • Orange end cap gaskets (#5 in picture)
    • Blue o-rings to seal to bricks to the intercooler manifold (#6 in the picture)
    • Metal hold-downs and bolts that secure the bricks to the supercharger casing (#7 in the picture)
That’s correct. @16GoManGoHC has the bricks for sale
Above is correct, thank you 707
Just sold a lid, set of bricks with orange silicon gaskets and hold downs, and bypass black seal.
I have a set of bricks, and another set of bricks with hold down bars and orange end seals. I also have a few bypass valves and gaskets. Message me if interested.
