Hey all,
I'm sure this has been beaten to death on here by now but I have a few questions beyond getting a new clutch. Last weekend I smoked my clutch at the drag strip. After second gear my cat did not want to shift and I coasted to the 1/8th turn-off. On my way back I was able to shift and drive it back to the parking lot but the shifts were a nightmare. Upon leaving the track shifting into first was a matter of forcing the shifter into gear and as I pulled away first just felt nasty and had a bit of hop. Driving home all other gears felt like there was an obstacle or block to get it into gear but not as bad as first. When trying reverse it is the hardest of all. I literally have to force it into gear.
Here comes my question. The car obviously wreaked of burnt clutch. Do you guys think this is just a clutch issue or do you think something else may be damaged as well? I'm on the enlisted end of the low pay scale in the military lol. With that being said I need to choose my next steps carefully.
I have since read about how crappy the stock clutches are. I would definitely not meet the one-time factory replacement criteria. I am considering a Bad Boyzz twin disc clutch but depending on your guy's recommendations I may need to re-evaluate if I may some other issues going on based on the symptoms. In past manual vehicles, I have never had a hard time getting the trans to go in gear even if the clutch was toast.
Until I get this figured out the cat will just sit in the garage. If a Bad Boyz twin disc setup sounds like a fix and someone has a list of all of the special tools I would need to procure I would greatly appreciate it. I'd rather buy the tools than pay someone else to do it. If anyone has advice, I would greatly appreciate it.
Cheers,
Hud
Cheers,
Hud
